Download
How to Copy DVD to DVD in an Easy and Professional Way?
Are you looking for a versatile, powerful yet user-friendly DVD copy tool to back up your DVD movies? Then you can never miss out DVDFab DVD Copy. As a professional DVD copy solution, it provides you six copy modes and allows you to copy DVD disc to ISO file or DVD folder. In addition, its interface is modern, sleek and intuitive, so everyone even a novice can learn it quickly. Now let’s have a look at how to copy DVD to DVD with DVDFab DVD Copy.
How to Copy DVD to DVD in an Easy and Professional Way: Step 1 > Run DVDFab 10, choose Copy module and click the "Copy Mode" tab on the top left corner of the main interface to choose a copy mode. You have 6 modes to choose. Here I take Main Movie mode as an example.
How to Copy DVD to DVD in an Easy and Professional Way: Step 2 > Load the source.
How to Copy DVD to DVD in an Easy and Professional Way: Step 3 > After the source is loaded in, the longest title, namely the main movie, will be selected by default. Then you can change the chapters, audio tracks, subtitles and do advanced settings according to your needs. On "Advanced Settings" panel, you can decide the output as DVD 5 or DVD 9.
How to Copy DVD to DVD in an Easy and Professional Way: Step 4 > Navigate to the bottom of the main interface to select a directory to save the output DVD: to select your optical drive as the directory from the drop-down list box is to save the output to a blank disc; to select a directory by clicking the "folder" icon is to save the output as a DVD folder; to select a directory by clicking the "image" icon is to save the output as an ISO image file.
How to Copy DVD to DVD in an Easy and Professional Way: Step 5 > Click the "Start" button to start the copy process.
Note:
6 modes:
If you choose to save the output to a blank disc, you will be promoted to insert a compatible media to your optical drive during the copy process. Just insert a blank disc to continue the copy process.
For more detailed information about DVDFab DVD Copy, please visit http://www.dvdfab.cn/dvd-copy.htm.
  • Discount
    FAB-HXH-OFF
    Jun 26, 2017
    for Buying
    The Universal Master Key
    Price: $60 Buy Now
    World's Best DVD Combo
    to Tackle All DVD Copying/
    Price: $79 Buy Now
